39?A
Pitch
12-31-2003 19:34:14
I have a different color tractor, but a guy at work has what he says is a '39 A. Wanted to convert to an alternator cause he goes through a generator evry 4 to 5 years, any way in the discussion he said that it was a 12 volt system and had 2 six volts hooked together. Is this a true 12 volt system or does it start on 12 and run on six?
F-I-T
12-31-2003 20:34:49
 Re: 39?A in reply to Pitch, 12-31-2003 19:34:14
Pitch:
Are you sure he isn't talking about a '49 "A" maybe?
I believe that only a single 6 volt battery was offered in the the '39 models as the only place to store them was in the front frame or under the hood in front of the gauges later on. This continued through '46.
In '47, when Deere came out with the square battery box under the seat, the "A" was offered with 2-6 volt batteries in series which powered a 12 volt system.
A '39 "A" would have come with a magneto, so there was no battery power involved. Of course a lot of those tractors were converted to distributors over the years.
Frank
