4020- Hyd. problems
Rickey
01-03-2003 18:28:19
Still having trouble. I recently got some excellent advice about how to build a check valve in my hyd. lines to keep the hyd. fluid in the pump so I would have loader operation at startup. That works great now. but while I use the clutch and loader controls at the same time I lose loader response. I am using hygard and new filters. Any advice ???
Gordon
01-06-2003 16:53:22
 Re: 4020- Hyd. problems in reply to Rickey, 01-03-2003 18:28:19
JD all ready put a check valve in the tractor.It is below the trans pump.
Dave T.
01-03-2003 19:13:29
This is normal because when you depress the clutch you disengadge the transmition hydrolic pump that feeds the main front pump. They do make resevoirs to install in front of the radiator to help with this problem.
Dave T.
