John Deere M Axle removal
Matt
01-03-2003 11:46:11
I need help on getting the axle out of the houseing on an M JD. I see it is tapered into the gear but don't see any way to remove it with out damageing things. Any ideas?
Matt
01-03-2003 13:11:06
 Re: John Deere M Axle removal in reply to Matt, 01-03-2003 11:46:11
I am trying to remove the axle with the wheel off. It is an M JD.
Clooney
01-03-2003 13:29:49
 Re: Re: John Deere M Axle removal in reply to Matt, 01-03-2003 13:11:06
Matt, did you remove the inner axle retaining bolt & retaining plate? If so remove the outer quill [cover] then try to drive the axle shaft out of the bull gear with a brass drift & hammer. Usually it will come out. If not, you might try a piece of pipe with a diameter big enough to sit on the outer final drive quill surface & a piece of steel across the pipe with a hole in it that the outer wheel retaining nut can be tightened against & used to put a pulling force on the axle while you drive it from the rear with a brass drift & hammer.
Clooney
01-03-2003 12:58:20
Matt, are you working on a standard M or an MT? Do you have the cast wheel off or are trying to remove the axle from the bull gear with the cast wheel still on the axle?
