38G More Specific Questions
Wind
01-03-2003 11:07:50
As posted below, I am doing a little research for a friend and am far from knowledgable about G's. "Easy Does It" prompted several more questions from me, so any information is greatly appreciated.
1) Through what serial # were low radiators? And did Deere replace/rebuild most of them?
2) What key factors would define a low radiator? Height of core, block style, or anything else?
3) Easy said he didn't think G's were produced with round spoke rears. How would I know if they were not stock? Size, axle size? What I did find interesting is that the hub has onlt 3 bolts while my B has 4, that seemed a little strange.
Again, any help is appreciated. I am sure we will have more questions.
Some answers
01-03-2003 19:42:46
 Re: 38G More Specific Questions in reply to Wind, 01-03-2003 11:07:50
1. "Low Radiator" "G" tractors were built from G-1000 through G-4250. Most tractors were rebuilt with the larger radiators and associated parts in the field. However, it was not a mandatory program, and so some tractors were not rebuilt with the new parts.
2. Easiest way to determine a "low radiator" is that the steering shaft will clear the top tank by about an inch or so. Tractors converted to the larger radiator will have a groove in the top tank to clear the steering shaft.
3. Round-spoke rear wheels were available for "G" tractors, but the first "G" to have them was G-2709. The tractor you are talking about, G-2292,
was built 9/20/37 and shipped 9/21/37 to Monmouth, IL. It is listed as having AF8 wheel equipment, which was rubber front tires on pressed steel wheels and skeleton steel rear wheels, so this tractor was converted to rubber later in life. FRONT round-spoke wheels were never available as factory-installed wheel equipment on "G" tractors.
