Jd 2 bottom plow
scott
01-02-2003 16:40:24
have found a jd 2-12 hyd lift plow with round spoke wheels on it..appreas in god shape other than tires bad and missing cyl. could find a # on it but was wondering what it might be for and if the wheels would fit a jd tractor?..value of this implement..realize this is nt much info to go on but would appreciate any help..thanks
Lary
01-02-2003 21:13:11
 Re: jd 2 bottom plow in reply to scott, 01-02-2003 16:40:24
Sounds like a 44H , In Michigan it would be worth about 175$ if it has coulters ,want to sell it?
ron in MN
01-02-2003 19:02:16
with bad tires it's not worth more than $50. With hydraulic lift it is probably a model 44. The cylinder not there doesn't mean it's missing. The cylinder used was the remote cylinder that was with the tractor.
PeteNY
01-02-2003 18:39:11
Scott, where are you located? I'd be interested in seeing a pic if you're gonna offer it for sale. Pete
gene
01-02-2003 18:05:45
more then likely you have a model 52 think i some times get the numbers of plows confussed, but a hyd 2 bottom plow is worth about 150 at least that is what i have been getting out of them when i get one that i dont want. the wheels will not fit a tractor they are a implement wheel not a tractor wheel. the hubs are alot different.
johndeeregene
jdman(MO)
01-02-2003 20:42:44
 Re: Re: jd 2 bottom plow in reply to gene, 01-02-2003 18:05:45
I have a model 52 it is steel wheeled and and a rope trip. They came out on steel, but a lot of them were converted to rubber. He probably does have a model 44. Russ
gwh
01-02-2003 19:55:29
Gene, Do not believe i ever saw a number 52 hydraulic plow? gwh
