2010battery hooked wrong john T?????
RayHudson
12-31-2003 16:08:05
we put battery in 2010 wrong - ground After I changed it red light wont go out its has original generator system I forgot how to polorize regulator tell me again and I will Write it on the wall of new shop
John T
01-01-2004 13:57:14
 Re: 2010battery hooked wrong john T????? in reply to RayHudson, 12-31-2003 16:08:05
Ray, to polarize, once all is hooked up, momentarily flash jump a wire from the BAT terminal on the Voltage Regulator wire over to its ARM (Or GEN) terminal terminal and you should get a small spark. Same is accomplished if you jumped from the VR's BAT terminal or any hot wire to the Armature post on the Generator.
If you apply voltage to the generators Armature (case must be grounded) if it motors, the armature and brushes are good. Then, if you ground out the field winding and it slows down some, the field windign is good. Perform BOTH tests and post back results.
If you want my standard instructions for how to test if its a generator or a voltage regulator problem, post back or e mail me at [email protected]. You may have a bad Voltage Regulator???
John T
Ray
01-01-2004 13:38:08
the generator motors when hooked to a battery does this eleminate gen problems I took it apart cleaned blew it out I didnt see any problems
