57 JD 820 Tires and Rims
Paul
01-01-2003 19:44:40
I am looking at an 820 with tires and rims that are just plain junk. I have been told that you can use the tires and rims off of a JD 105 combine on the 820, can anyone verify that. Also are there any other possible replacements that could be used?
scottAR
01-02-2003 19:50:48
 Re: 57 JD 820 Tires and Rims in reply to Paul, 01-01-2003 19:44:40
I've seen several MM tractors (GTB, GTC, GB, GBD, GVI) with tires and rims from JD combines, (55, 95 & 105) so I assume it could go the other way. I think but am not certain that the fat hand clutch Case tractors had cast centered hubs also. I'm talking LA thru 930 Standard. The 930 Standard may have had 30 inch tires though. All the others I'm refering to are 23.1X26 or 28L26 on the combines and tractors. All the 820& 830 around here had 26s.
