John Deere H torque specs
Woody
01-01-2003 19:01:22
I have gone to the following web site for torque specs: Link However, there is nothing there for a JD H. Does anyone know what the rod bearing caps and head bolts are supposed to be torqued to?
Donny-B
01-01-2003 19:24:06
 Re: John Deere H torque specs in reply to Woody, 01-01-2003 19:01:22
According to the I&T manual, 62.5 ft/lbs. I would suggest purchasing an I&T manual(JD-4) as they are very handy for most repairs and cost about $18-$25.
Woody
01-02-2003 08:43:32
 Re: Re: John Deere H torque specs in reply to Donny-B, 01-01-2003 19:24:06
I called to order an I&T manual and John Deere told me that theirs wasn't that good. They gave me a phone number where I could order a better one. Well, it wasn't much good either. Is that 62.5 foot pounds for the head bolts or bearing caps or both?
Donny-B
01-02-2003 12:37:27
 Re: Re: Re: John Deere H torque specs in reply to Woody, 01-02-2003 08:43:32
Woody, I also ordered a John Deere manual (SM-2000) that was suppose to be better then the I&T for major repairs. The manual is very helpful for carb and electrical repairs but is not geared to mechanical repairs. The I&T gives you the basic steps on repairs with torque specs but without prior experience working on these tractors you should ask mechanics at the JD dealer or people on this board for help.(I do) The 62.5 ft/lbs is for the rod caps. The head bolts are 96 ft/lbs with the exception of the oil stud.(180 ft/lbs)
Woody
01-02-2003 21:06:43
 Re: Re: Re: Re: John Deere H torque specs in reply to Donny-B, 01-02-2003 12:37:27
Thank you for the info. That will help a lot.
