Adjusting tread
hardscrabble
01-01-2003 17:42:57
I have a '49 AW on which I would like to extend the tread. Neither the front or rear wheels have been moved since it was new, so I'm sure things are rusted together. Are there any tricks to loosening the rear wheels, and the front axle? I've removed the clamp from one rear hub and driven the tractor around the yard, but it doesn't appear to be loosening.
Ron
01-01-2003 18:19:34
 Re: adjusting tread in reply to hardscrabble, 01-01-2003 17:42:57
We always jack the wheel up after the clamp is off, then wet the spline area with oil/kerosene then hand-spin the wheel, and hit the brake, to break it loose..( may have to repeat several times)... Once loose, we run a chain thru the "chain holes", to the drawbar of another tractor ( or anything solid)... Turn the wheel, to wind up the chain and the wheel will be slid out... We use the same chain, to pull them back in...wrapped around the axle housing bolts...
