44jdA idle screw vacuum leak through threads.
cam
01-01-2003 16:18:32
can anyone tell me how to correct a vacuum leak of air coming from the threads of the idle adjusting screw. thanks cam
Clooney ***Happy 2003***
01-01-2003 18:36:49
 Re: 44jdA idle screw vacuum leak through threads. in reply to cam, 01-01-2003 16:18:32
Cam, if the leak is bad you probably have plugged air cleaner, or plugged idle passage vent, or bowl vent restriction.
~If the needle isn't too loose, probably a little Teflon pipe sealer [NOT Teflon tape] on the threads will do it. If the needle is loose or the leak is bad then using a small "O" ring or two between the needle & carb casting will stop your leak...
phil
01-01-2003 17:47:44
Perhaps the spring that loads the detent ball is weak. A strong spring will load the threads on the idle screw so that leaking is minimal. A weak or missing spring will allow the threads to rattle freely & allow an air leak.
