Gear reduction cover 1944 B
Wayne Johnson
01-01-2003 15:45:05
I want to adjust the main bearings. I have the clutch out and all the bolts out of the gear reduction cover but it seams to be catching on the bearing on the reduction gear. Any advice?
Clooney ***Happy 2003***
01-01-2003 16:02:01
 Re: Gear reduction cover 1944 B in reply to Wayne Johnson, 01-01-2003 15:45:05
Wayne, have you pulled the castle nut from the end of the input drive gear? There is a snap ring behind that bearing so you can't just pull the cover off over the bearing. You might have to bump the end of the input shaft with a soft hammer to get it to slide through the bearing.
