JD B Clutch
Jake
12-31-2002 12:35:34
The splines on the drive disk are wore down and the splines on the crank are wore. Is there a kit somewhere you can buy to fix it or how do you go about fixing this?
Gordon
12-31-2002 17:16:17
 Re: JD B Clutch in reply to Jake, 12-31-2002 12:35:34
Years ago I work on a 40 B. He ran it so far that the crank spun in the driver. It took about a day I brased and filed splines on. All I had to work with was some marks where the splines were. Today with a wire welder and the grinders that are out there it is better. I did this to both sides all ready from the B to 730D. I did not have any problems . Keep your driver square to crank. I never pulled the crank to do it.
John T
12-31-2002 12:50:01
Thay manufacture undersized cluth drive disks for that very purpose. Dengler Tractor in Ohio 513-423-4000 has them in about 5 or 6 different undersizes. www.expresspages.com/d/denglertractor
Be sure and get the new one back on in time otherwise its vibration city. Ol John T Nordhoff in Indiana
