2020 diesel problems
toot
12-31-2002 05:51:56
The tractor has a miss, and seems to have no bottom end power. All of this happened out of nowhere. Has new filters installed but makes no difference. Any thoughts?
cannonball
12-31-2002 17:12:22
 Re: 2020 diesel problems in reply to toot, 12-31-2002 05:51:56
had a 219cu in jd go to missing just out of blue, had injector stopped up, found out which one by running tractor and loosing line at pump..happened again and had line cracked,,,have nice day may god bless
2020 in mn
12-31-2002 09:31:54
Any temperature concerns that may have caused fuel to gel? Here in MN we've got to add some anti-gel as the temps drop.
Gordon
12-31-2002 06:29:00
What pump do you have? JD use a throw away pump on some of those tractors. Then they got to expensive to throw away.The rosa-master was the better pump. They also can have some problems.
ET
12-31-2002 05:58:21
You may have a bad injector. Pull the fuel return line off the injectors and start the engine. The bad injector will be dumping a lot more fuel out the return than the other injectors are.
gwh
12-31-2002 16:24:10
 Re: Re: 2020 diesel problems in reply to ET, 12-31-2002 05:58:21
ET, Yeh Happy New Year. gwh
