Idle screw turns by itself.
B popper
12-30-2002 11:54:50
I have a 1946 B. The idle screw turns by it's self. When turning the screw, no clicking is felt as I turn it.
The load screw clicks. I had the neighborhood mechanic work on the carburetor and I think he lost whatever locks the screw in place. What am I missing and where do I get the piece.
Thanks for any input.
mfrancis
12-31-2002 06:40:36
 Re: idle screw turns by itself. in reply to B popper, 12-30-2002 11:54:50
If you need to use tractor while your waiting on parts, just take some silicon anfd set it where you want it and get by till you get it fixed right. Just a hillbilly solution. Hope it helps you out
mike3
12-31-2002 09:29:17
 Re: Re: idle screw turns by itself. in reply to mfrancis, 12-31-2002 06:40:36
wrap a rubber binder around the load and idle screw heads to stop un wanted movment
John T
12-30-2002 12:11:56
Mine did that because the small steel detent ball with the spring behind it that clicks up against the knurls in the idle needle top had fallen out. You may be able to purchase the spring and detent ball from Robert Beaver's web site Link Ol John T Nordhof in Indiana
Clooney
12-30-2002 12:10:10
B popper, the friction ball is either missing or stuck in the bore or the spring is weak or broken. Not the easiest to replace, but can be done with some patience. Roberts Carb [Phone: (712) 262-5311] has the spring & ball.. [R10175 Friction Spring,,R10038 Friction Ball]
