JD A upper water pipe
bruce
12-30-2002 08:02:15
Is this pipe sweated into the elbow? Not sure if I can get just the pipe,or if I have to live with this one. Thanks Bruce
Craig
12-30-2002 21:10:46
 Re: JD A upper water pipe in reply to bruce, 12-30-2002 08:02:15
My B was brazed in with brass. It took a big rosebud torch to get enough heat on the whole thing to get the old one out and new one in.
jdmanMO)
12-30-2002 09:33:22
As far as I know all A and B upper water pipes are sweated into the Cast Iron Fixture on the Block. Takes a good sized torch to get the old one out and install a new one. I used muffler pipe to fix mine. Probably last longer than I do. Russ
Ron
12-30-2002 09:26:52
My "60" has an "O" ring in each end fitting....
They need to be replaces once every 20 years, or so..!! I use Black gasket maker on the pipe end, to help it slip in place, and it helps seal, too...
I would think the "A" would be the same...
