Deisel transfer pump problem
pdl
12-29-2002 18:40:22
The transfer pump on my JD 80 suddenly started leaking from between the pump body and the block which it bolts to. I replaced the seals , aadded a felt washer between the sseals which I-T said to do aand put on a new gasket.Now it leaks worse than before. HELP!
Clooney
12-29-2002 19:52:11
 Re: deisel transfer pump problem in reply to pdl, 12-29-2002 18:40:22
Pdl, do as Frank said & check the running pressure. If that is ok then recheck the seal installation & or drive gear shaft to housing clearance.
~Did you install the seals with the inner seal lip towards the pump & the outer seal lip towards the engine? Did you put a Permatex type sealer on the seals od? Did you remove any burrs from the drive gear drive end so you didn't knick the seal lips on installation?
~I don't see any reason to send the pump out, there isn't much to those pumps & getting those seals to hold shouldn't be a problem. My biggest problem has always been getting enough pressure out of them.
F-I-T
12-29-2002 18:51:12
pdl:
Did you have any noticable wear grooves on that driven shaft where the seals rest ? I had one that was very worn, but Albert @ Renaissance Tractor was able to salvage it for me during the rebuild. He uses newer type seals that won't rest in the same spot.
You might want to contact him.
The last e-mail I have for him is: [email protected]
Frank-in-Tallahassee
70D // 855
pdl
12-29-2002 19:14:34
 Re: Re: deisel transfer pump problem in reply to F-I-T, 12-29-2002 18:51:12
Thanks guys! The shaft didn't look worn or groved.Ialso used the newer seals. I think the spring loaded ball may be the problem because when I remove the bleeder plug from the pump the litttle ball seems to stick and not drop out without a tap on the pump. Do you think its a good idea to just have the pump rebuilt?
Another thing.....
12-29-2002 18:54:11
Did you check that little spring/ball pressure relief valve ? If it is stuck, the pump will build up too much pressure after the filters and rack are filled, and the only place for that pressurized fuel to go will be down the shaft and past those seals.
F-I-T
