John Deere 40U rear oil seal
Andrew
12-29-2002 12:02:40
I am tiring to replace the oil seal on the final drive. I can't get the cast hub off or get the shaft to slide off the final drive gear. Any idears would be great.
Bill
12-29-2002 16:18:50
 Re: John Deere 40U rear oil seal in reply to Andrew, 12-29-2002 12:02:40
I tried everything on my 40S to get the hubs off,
nothing worked. I built a puller and was using a 20 ton jack and all it did was stretch the 5/8" bolts. The hubs are drilled 5/8" so that's the biggest you can use. I tried heat, penetrating oil, hammering, no luck. Then someone told me to pull the axle shaft out with the hub still on, the shaft comes out of the bull gear much easier. Pull the outer quil and inner cap. Support the hub with an engine hoist to hold the weight. Thread a short bolt into the end of the axle shaft to hammer on. I was able to drive the axle out of the bull gear with a large hammer, took a couple of minutes. I had been working on trying to get the hubs off for quite a few hours spread out over several weeks. With the hub and stub axle shaft free from the tractor you can either use a large press, or what I did was just drop them. Put the large nut on the end of the axle, without the washer, making sure the nut is flush with the end of the axle. Put a piece of heavy steel plate on the concrete floor and then drop the hub/axle on it from about 6" or so high. One of mine popped free on the first drop the other took two drops if I remember right. Worked great for me, give it a try.
Andrew
12-31-2002 02:58:45
 Re: Re: John Deere 40U rear oil seal in reply to Bill, 12-29-2002 16:18:50
The drop theory did not work. My brother and I tried it for over two hours. Andrew
Clooney
12-29-2002 14:02:27
Andrew, usually lots of heat & a big puller is needed to get that cast wheel off. Once the cast wheel is off the inner end of the shaft, you should then be able to drive the shaft from the bull gear [after removing the inner retaining plate & outer quill]. Be careful when working with that cast wheel, I broke a rib pulling one of those cast wheels from a 40-S some years ago.....
