I need oil line for 60 JD
Dale
12-29-2002 07:45:29
I need the right main bearing oil line for a 60 JD. I'm sure an A is the same. This oil line runs from the oil filter head to the right "clutch side" main bearing housing. Thanks
Jerry S
12-30-2002 09:25:46
 Re: I need oil line for 60 JD in reply to Dale, 12-29-2002 07:45:29
Assuming you have your old line, you might want to take a trip with that old line to the hardware store and see about using compression fittings and bending your own line for it. With the low compression the motors run, you could bend a new line and put the compression fittings in and should work OK I believe. It worked on Dad's A several years ago and we used copper tubing.
