Clooney
12-29-2002 05:01:07
Re: fouled plugs in reply to tom , 12-28-2002 21:48:00
Tom, the information you furnished is a little confusing. You say "the plugs keep fouling out (burnt)", are the plugs fouling out [black soot, wet fuel, wet oil, etc.]? Or are they burning [melted electrode, larger gap, signs of overheating]? ~If they are fouling from fuel or oil & turning black then you are fighting a weak ignition, wrong ignition wires, or rich carburetion, or poor sealing piston rings, or too low a heat range spark plug, or fuel additive problem, or plugged air cleaner/intake. ~If they are burning, then you are fighting a lean carburetor, or lack of fuel flow, or low fuel octane, or over advanced ignition timing, or too high a heat range spark plug. ~What are you running for engine specs, compression, ignition timing, carburetor, type of mag/distributor, air cleaner, any other engine modifications? ~What are you running for fuel? Any fuel additives being used? ~Let us know what you have, & what you are running, & what exactly is happening to your spark plugs, then we can probably help..... .
