JD 40 stuck transmission
Kent
12-28-2002 18:21:04
I used the JD40 on Christmas day to plow snow with no problems. On the 26th, I drove down the road to plow the neighbors and upon arrival it is stuck in 4th gear. Any suggestions????
Thanks.
Clooney
12-28-2002 18:26:29
 Re: JD 40 stuck transmission in reply to Kent, 12-28-2002 18:21:04
Kent, we need a little more information. Is it stuck in 4th with the shift lever in the 4th position also, or is it stuck in 4th with the shift lever in another position like neutral?
Kent
12-28-2002 18:38:24
 Re: Re: JD 40 stuck transmission in reply to Clooney, 12-28-2002 18:26:29
I appears to be stuck in 4th position. When I arrived at the neighbors, I pushed the clutch in and attempted to shift into reverse and that was the first sign of any problems. I then attempted to go into any other gear and the shift lever has a little play but won't budge out of 4th gear. Slowly let the clutch out and limped home and into the garage.
Clooney
12-28-2002 18:46:46
 Re: Re: Re: JD 40 stuck transmission in reply to Kent, 12-28-2002 18:38:24
Kent, it could be a trans shifter malfunction but if it's below freezing where you are you might have some water in the trans & it ended up on the trans sliding gear shaft or shift rail & froze.
~If it is below freezing where you are, see if some heat or warm up will free the shifter. If it isn't below freezing where you are, then you will probably have to pull the trans top shifter cover & take a look to see what has malfunctioned.
