JD3010 any good?
Dick
12-28-2002 11:17:43
I'm new to this board been on the N side.Just traded a MF1086 for the 3010,gave my son the "N" was reading a post about some one else looking for a JD (from the N side} He was told to stay away from the 1010 &2010 because they were four cyl. does that mean a 3010 is just as bad? Maybe I should get my N back?
Dick
12-28-2002 16:07:35
 Re: JD3010 any good? in reply to Dick, 12-28-2002 11:17:43
Hey thanks for the info was worried,but should know better.I've got a 73 JD140 garden tractor with over 2500 hrs on the clock.The N was a good utilty tractor never gave me any trouble,but just would not plow in muck,got the MF cheap did what I needed to do, this will do the samewith out having to keep it pluged in when its cold.Again thanks will be back on here alot.
mike
12-28-2002 12:27:21
A 3010 is at least 5 times the tractor your N
was,you have live pto,live hydraulic,and you can
actually do something with them compared to
a pretty much useless ford.
CLW
12-28-2002 11:33:13
Dick, you need not worry. The 3010 was a good tractor. They are 42 years old so they may have some problems due to wear as with the N or any other tractor, but they are not the same as 1010 and 2010. Not all 1010 and 2010s gave problems but more than a few did.
CLW
G-MAN
12-28-2002 11:28:42
The 3010 is a completely different animal than the 1010 and 2010, and they are good old tractors. The 3010/4010/5010 are Waterloo tractors, and the 1010/2010s were built in Dubuque. There's not a lot common between the two different breeds other than the paint and the name. 3010s have pretty good engines, closed-center hydraulics, a good tranny, excellent power steering, are comfortable and so forth. All they want is good maintenance and they will run well and perform well for a long time.
