40 T Brakes
Daniel
12-31-2003 07:18:05
I need to overhaul the brakes on my 1955 40T. Where is the best place to get new disks, springs, balls, etc. for the brake system. What kind of price range do you think this will be in. I heard these parts are hard to come by and very expensive.
I appreciate any info you fellows can provide me with.
Thanks,
Daniel
Wayne in Tn.
12-31-2003 07:44:37
 Re: 40 T Brakes in reply to Daniel, 12-31-2003 07:18:05
Daniel, yes all the parts you mention will be expensive if bought new. Those brakes are easy to get to and work on. Usually a dissassembly and a good clean up will put them working again. Sand the surfaces down to bare metal, sand and clean the balls and mechanism good, a drop or two of oil on the balls will help. If the pads or discs are not completely shot, you can sand them and clean with carb. cleaner. Another tip is to remove the adjusting nut and install a spacer, like a lug nut, then put the adjusting nut back on and adjust up. This will give you more adjustment to acheive a full pedal. Look for any broken linkages ect. They can be welded or repaired. You can get used parts if needed, from someone like John Shepard or other vendors.
Dan
12-31-2003 07:39:05
You can get the discs from the tractor parts link at the left, think they are less there than deere but I haven't priced them through JD for a while. The balls may be fine if cleaned up and springs available through JD. Take them apart and look them over before ordering anything, my just need cleaning.
