JD 1250 4WD, any good?
eb77
12-25-2002 18:39:17
Local dealership has a JD 1250 4WD with large diameter front tires. I am looking at it to add a loader. Are they durable? Should be about 40 HP.
leon
12-26-2002 04:07:58
 Re: JD 1250 4WD, any good? in reply to eb77, 12-25-2002 18:39:17
Yep, in general these were darned good little tractors. Very reliable. If the mechanical basics check out OK and the appearance suits you - and the price is right, I don't think you'll go wrong. As most unique parts will have to come from Japan, they'll not be cheap - but then you shouldn't need many. With the MFWD, it would make a good loader tractor. Remember rear end weight.
Unless you've already fallen in love with it, waiting and searching for a good 4-cylinder engine model 1450 (50 hp) or 1650 (60 hp) tractor with MFWD might be an even better bet.
