49 'A' plugs
morgan
12-25-2002 18:30:48
My 49 A seems to eat the plug on the right side. I use champion D-21's and she runs great but I have to change the right one often. I can tell when the right plug goes , because under load she will start bogging down and back-firing,and lose power. Just today had to change the right plug out so I put 2 gaskets (plug washers) on and I will se if that makes a difference. Maybe I should use a different kind ? Thanks-morgan
JD A Puller
12-26-2002 20:52:54
 Re: 49 'A' plugs in reply to morgan, 12-25-2002 18:30:48
hey morgan, I pull a 1951 A John Deere that has a hott motor in it and i only use one brand of spark plugs those r AC Delco 87's.I can put them in it at the beggining of the year go to 23 pulls all year and all i have to do is take them out bout 1 or 2 times all year and clean them.I also have them in my 48 G John Deere and they do excellent in them both. Hope this helps!! HAPPY NEW YEARS!!!
morgan
12-27-2002 08:11:28
 Re: Re: 49 'A' plugs in reply to JD A Puller, 12-26-2002 20:52:54
A BIG thanks to you and HAPPY NEW YEAR to you and your family !! morgan
ChuckW
12-25-2002 19:24:10
I had to go to electronic ignition to get rid of this problem. Your problem is quality of unleaded gas and low temperatures, too light of spark. If you have a distributor, delco type go to the electronic. There was article in Green Magazine last month about this, as a matter of fact man had an A.
Terry H
12-25-2002 19:19:36
morgan,
The old right plug problem..... ..My '50 a does the same thing from time to time. It's due to the fact that under light loads, the right cylinder draws less fuel than the left (among other things). If you search the archives on this board, there have been dozens of posts on this same subject (and a lot of spark plug opinions!) What I do is clean up the plug and if it isn't too bad, swap it with the left one.
Good luck,
Terry H
Lary
12-25-2002 19:11:04
morgan; Switch to Autolite.
Lary
12-25-2002 19:10:13
morgan; Switch to Auyolite.
Will P
12-25-2002 18:40:54
Allot of people, including me, don't like Champions. I have had the best luck with Autolite 386's I use them in my 43B and I will be using them in my 49G once I get it up and running. If I remember right, 386 are best to use in working tractors and 388's in parade tractors. I have had the same plugs in my B for over 1 and a half years. Champions would last one month. Give it a try.
Will P
morgan
12-25-2002 19:17:55
 Re: Re: 49 'A' plugs in reply to Will P, 12-25-2002 18:40:54
Thanks, I will give it a try!! Today with this plug I changed makes it the 5 th one in about 5 months. all on the right side. I was blading the snow from my drive way today. the old tractor sure runs nice and starts easy and quick. considering we got down to 15 deg. last night and my A was part of my wife's christmas light decoration, so she was out side in the weather(the tractor that is!) I went out side and unpluged her from the lights and hooked up the blade to move some snow around. Thanks again-morgan
Will P
12-25-2002 19:25:47
 Re: Re: Re: 49 'A' plugs in reply to morgan, 12-25-2002 19:17:55
My 43B sits out side too. I can start it down to about 10. Anything below it probably won't start. It is a hand start.
Give the plugs a try. You will like :-)
Will P
