70 flywheel vs 730 flywheel
kelly
12-25-2002 18:28:01
will a 70d flywheel work on a 730d? i have a 70d flywheel but i need 1 for a 730d that i am trading for. thanks
Mike
12-28-2002 07:39:33
 Re: 70 flywheel vs 730 flywheel in reply to kelly, 12-25-2002 18:28:01
Should work the early ones have a slinger drive pin that will need to be pulled out because the 730 and late 720 had a normal oil seal that did not use the slinger.
Diesel Dan
12-28-2002 08:28:42
 Re: Re: 70 flywheel vs 730 flywheel in reply to Mike, 12-28-2002 07:39:33
Mike;
I think you are misinformed both all the 70 through 730 diesel flywheels use the D 2009r drive pin with a key driven flywheel spacer.
Clooney
12-25-2002 18:50:25
Kelly, the 70 & early 720 are the same but the late 720 & 730 are different. I don't know if the early one can be modified to work on the late. Try calling Albert at Renaissance Tractor [1-800-784-0026], he is the expert on those diesels....
