Film and rust deposits in cooling system on '51 A
Herb
12-25-2002 18:19:53
I am replacing the radiator in the '51 A. The coolant pipe is coated with a brown rust film. I am wondering if this material will plug the new radiator core. What solvent can be used to clean the cooling system?
Thanks,
Herb
C
12-25-2002 21:10:51
 Re: Film and rust deposits in cooling system on '51 A in reply to Herb, 12-25-2002 18:19:53
If the coating is stuck on tight it probably will stay there.
When I had my 1950 B apart I sandblasted the insides of the pipes clean. However that uncovered all the pin holes in the upper steel pipe. I was going to patch it up but instead found a piece of that difficult-to-find diameter pipe and made a new pipe. It happened to be twice the thickness of the original and I figure if the original lasted 50 years, my new thicker pipe should last 100 years.
