Carb. problem on 44 JD A
new to jds
12-24-2002 10:42:23
the carb on my 44 A is not workin right does not idle, hard to start because floods plugs out.had the thing apart my self but could not get the little small brass screws out allready striped .watched roberts video onrepair.thinking about sending away to have rebuilt .who does cheapest but good work? not made of money. thanks for any and all info.
Clooney
12-24-2002 11:55:50
 Re: carb. problem on 44 JD A in reply to new to jds , 12-24-2002 10:42:23
jds, there are certain things you can do without pulling those brass plugs. Make sure the float is good, not fuel logged & set correctly, make sure the choke is fully closing, & opening, [just because the linkage is moving correctly doesn't mean the choke plate is functioning correctly inside the carb]. The main nozzle can be pulled & all the little holes cleaned, the bowl vent can be verified to be open & the baffles not plugged. There are other idle system holes that can be checked without pulling those plugs. ~Those brass plugs can usually be removed if heated to a dull red then allowed to cool. Even if they are butchered up, a small pair of pliers can sometimes get them loose after heating. If worse comes to worse they can be drilled out & new plugs installed [#3, #14 & #21 drill bits]..... ..... [I use a L/H drill bit for the big ones]. ~Make sure the air cleaner is open & no water or crud is in the element or cup, [try running the tractor without the air cleaner hooked up to the carb].
~If you are intent on sending it out, Roberts Carb [Phone: (712) 262-5311] is about as good as any.
~If you want to give it another try, let me know & send me your E-Mail address, & I will send a carb cleaning diagram so you can check some of the areas that aren't under those brass plugs.
~You might want to try some heat [small flame tip torch] on those plugs, they might surprise you & come out easily with a small pliers or fine tipped chisel. [I use a little set of Snap-On ignition pliers that have good deep teeth & a short nose]
~Does it have a Wico "C" mag on it? If so, let us know as that could be part of your flooding/starting problem.
