60 Starter Ring
Terry
12-24-2002 04:16:20
Is the starter ring on the fly wheel reversible so that you can use the other side when wear is on the original side or do you have to replace it.
Gordon
12-24-2002 06:43:52
 Re: 60 Starter Ring in reply to Terry, 12-24-2002 04:16:20
I have taken the ring gear off and turned it 1/4 turn. You can knock it off with a punch. When you put it on heat to 500 degres to do that put oil on ring gear. Heat evenly when it smokes you will be close.Get it square it shoud go on.
John T
12-24-2002 06:35:01
Merry Christmas Terry, They sure are and use even around the rim heating around and around and around lol till shes ready to pry off and reverse. Ol John T
ChuckW
12-24-2002 04:40:10
Terry, I have had good luck by just rechampering the teeth in the current position as the reach of the starter gear is about an inch. If you didn't want to pull you can even heat the ring and move it on the wheel. Is a little move trouble and you have to be careful with the torch. However I take a small disc grinder and retouch the teeth in place. will be good for many many more years.
Clooney
12-24-2002 04:26:49
Terry, yes, if you want to re-grind each tooth chamfer to match the factory side. The ring gear teeth are ground at an angle on the starter side so the reverse side must be ground to match if the gear is flipped over. If you grind it to match, it will work fine.
