850 hyd oil filter
dave
12-23-2002 18:28:46
a friend just acquired an 850,serial # 16357 and changed most of the filters and fluids.the napa book says it takes a 1452 hyd filter,but he cannot find a location for it.called jd and they were of no help.does one of you know the story about this
tia
leon
12-24-2002 05:06:38
 Re: 850 hyd oil filter in reply to dave, 12-23-2002 18:28:46
The 850 you're talking about is a US sold tractor, it is a compact utility tractor made by Yanmar in Japan for Deere. The only thing it shares with the 1020 is the paint color. The on line parts book seems to indicate that the hydraulic oil filter was not used on this tractor if sold in the US or Canada.
leon
12-24-2002 05:24:20
 Re: Re: 850 hyd oil filter in reply to leon, 12-24-2002 05:06:38
If you start my earlier response with the word "IF", which I seem to have left out, it reads better and makes more sense. Apologize for that.
leon
12-24-2002 05:21:14
Steve - IN
12-23-2002 19:49:10
dave,
I'm guessing that the 850 you're talking about is a late 60's, early 70's utility tractor - and is a bit similar to my 1020.
If that's the case, you should be able to slide under the tractor a little bit behind and under where the brake pedals are mounted and find a bolt holding a round piece in a tubular sort of affair. That should be where the hydraulic filter lives.
Steve
mike
12-24-2002 16:26:59
 Re: Re: 850 hyd oil filter in reply to Steve - IN, 12-23-2002 19:49:10
Those tractors are numbered 820 and 830 built in the late 60's early 70's not to be confused with the two-cylinder's that used the same numbers.
dave
12-23-2002 20:10:50
Steve, thank you
Steve - IN
12-24-2002 10:12:26
 Re: Re: Re: 850 hyd oil filter in reply to dave, 12-23-2002 20:10:50
dave,
Between leon and me, there sure is a lot of "iffin" goin' on about this.
If the tractor looks like this one, it's a rice burner Yanmar JD - and my bets are off, and leon probably has the straight skinny.
third party image
If it looks like the tractor below, then it's a Mannheim Deere, and is probably fairly closely related to a 1020/2002 Dubuque machine.
third party image
Steve
dave
12-24-2002 12:16:01
 Re: Re: Re: Re: 850 hyd oil filter in reply to Steve - IN, 12-24-2002 10:12:26
steve,the 850 looks like the 1050 in the first picture.I think leon is right and it doesnt have the filter.
thanks you guys
JANEDEERE
12-28-2002 10:13:19
 Re: Re: Re: Re: Re: 850 hyd oil filter in reply to dave, 12-24-2002 12:16:01
IF YOUR 850 HAD A FIELD INSTALLED POWER STEERING KIT , THEN IT WOULD OF USED A JD # RE27284 FILTER. THE 850 WAS INDEED A PRODUCTION OF YANMAR FOR JOHN DEERE, THIS IS APPARENT ON THE ENGINE AS IT IS A THREE CYLINDER YANMAR 1.3L OR 1.7L.
