John Deere M alt
Nat
12-23-2002 10:58:04
I recently traded for an M. runs great, works great I have put a three point hitch on it and it will hold my bushhog up for a week I know. the problem is, the fellow I got it from had converted to 12 volts and that works good,except he left 2 wires sticking out of panel , he said to touch the wires together to excite the alt, to start charging,still not a problem,except i left the two wires touching last time I used it and it ran battery down.I am charging it now so I thought I would ask for a better way of doing it while waiting
John T (How to wire if its a GM 10 SI)
12-23-2002 14:45:19
 Re: John Deere M alt in reply to Nat, 12-23-2002 10:58:04
Nat, on many the 1 is R and the 2 is F, so in case you indeed have a General Motors 10 SI, here is how to wire it. Run a wire from the ignition switch which normally feeds the ignition that is HOT ONLY when the ignition is turned ON, in series with that wire add a 5 to 10 ohm resistor (Ive seen them with no resistor and up to 10 ohms and all worked) (5 watts power rated is more than required but will work fine) and a diode/rectifier rated for 50 VDC and 3 or so amps (1 amp rated will proably work and 5 is plenty) The diode should be polarized so positive is on the switch side and neg to the alternator. Connect that wire with its resistor and diode to the 1 or R on the alternator. Connect the terminal marked 2 or F on the alternator with a wire to the Battery Lead on the alternator. Run a No. 10 Gauge wire from the Battery Lead out the alternator to the load (non battery) side of the ammeter if you have one or to the non grounded battery post to charge the battery. This is for a negative ground system wiht a GM 10 SI internally regulated Alternator, so if thats not what you have, post back for more directions. Good Luck, Merry Christmas, and let us know how it works out. Ol John T Nordhoff in Indiana
Al Underwood
12-23-2002 16:16:31
 Re: Re: John Deere M alt in reply to John T (How to wire if its a GM 10 SI), 12-23-2002 14:45:19
Hey John T I have a 44 b with an old delco alternator on it without a regulater in it. I have an old regulator that came with it but dont know how to install it or where the wires go. Do I wire it like yuo said above. There are 4 pins on the regulator with no names on the pins. Where does the resister go.
John T
12-23-2002 17:09:53
 Re: Re: Re: John Deere M alt in reply to Al Underwood, 12-23-2002 16:16:31
The above was for an internal regulated GM with the 1F and 2R external terminals ONLY. If youre using an external regulator, I would have to know what alternator and regulator and if I have their diagrams, I can then advise further. Merry Christmas Ol John T
Nat
12-23-2002 12:31:01
well ,I went back to shop and batterery was charged, I looked at the alt and it does say delco. It has two larger wires out back and two on side, 1 above the other with the lugs vertical. I cranked the tractor up and scraped my gravel drive and shop parking lot. The three point hitch I made works great, it should, it took me 5 hrs to make and the steel and drawbar ends and pins cost $75.00 any way I thank you in advance for the answers,and Merry Christmas to all, Nat
Clooney
12-23-2002 12:58:23
 Re: Re: John Deere M alt in reply to Nat, 12-23-2002 12:31:01
Nat, are they [--] marked 1 & 2 or are they [.||.] & marked R & F?. I presume you when you say vertical they are [--]. If so, the easy way to go is the oil pressure switch with a 10 ohm 2 watt resistor in series with the wires going to the switch. The system will work with just the oil pressure switch but the 10 ohm resistor will protect the internal diode trio from damage from backfeed. Anything less than 8 ohms will still allow diode trio damage & isn't worth the cost of adding. There are a lot of systems operating without that resistor & in most cases they will operate ok for years, but it doesn't take much to smoke that internal diode so the 10 ohm resistor is highly recommended as protection. That is the way GM designed the system & used a 10 ohm resistor for gauge equipped & a 10 ohm light for idiot light equipped systems.
~You can go with a diode & resistor in the excitation wire from the switch to the alternator but on the "M" that involves pulling the dash panel [a real pain] & running new wires, so the oil pressure switch with resistor would be the easy way seeing as the wires are already there....
Nat
12-23-2002 13:33:31
 Re: Re: Re: John Deere M alt in reply to Clooney, 12-23-2002 12:58:23
Sorry, I don't mean to sound like an idiot, but they are marked 1-2 , and r-f, the lugs are in a line end to end 1 above the other.tks, Nat
Clooney
12-23-2002 13:53:55
 Re: Re: Re: Re: John Deere M alt in reply to Nat, 12-23-2002 13:33:31
Nat, the way to tell an internal regulated Delco from an external regulator model is by the way the terminals face. If they run in the same direction - - it is an internally regulated alternator & if they run parallel to each other | | then it is an external regulated alternator. There could have been some early units that used both the 1 & 2, & r & f but most SI-10 internals just use 1 & 2. If they have R & F only without any numbers then it is usually an external regulated unit. The "above one another" doesn't tell us much, it's the direction of the terminals that tell the story.
~I'll send you diagram showing the full SI-10 internally regulated wire routing, complete with diode & resistor for the M-40..... ..
Al Underwood
12-23-2002 17:07:54
 Re: Re: Re: Re: Re: John Deere M alt in reply to Clooney, 12-23-2002 13:53:55
Clooney, can you help me? I have a 44 b with an old delco alternator on it without a regulater in it. I have an old regulator that came with it but dont know how to install it or where the wires go. Do I wire it like yuo said above. There are 4 pins on the regulator with no names on the pins. Where does the resister go.
Clooney
12-23-2002 17:21:24
 Re: Re: Re: Re: Re: Re: John Deere M alt in reply to Al Underwood, 12-23-2002 17:07:54
Al, look at the regulator & see if it's a Delco, if so look closely at the terminals [pins] & see if there are numbers on them. With the base down & the terminals facing you there should be a # 4 on the far right & possibly a #1 or F on the left.
~Is it an electronic [has heat sink] or mechanical with a tin cover?
~If it is a Delco regulator, & you E-Mail me, I will send you a wire diagram I drew for someone a while ago. If not, confirm that the regulator is a Delco & I can help you with the pin out & wiring layout.
Al Underwood
12-23-2002 17:42:04
 Re: Re: Re: Re: Re: Re: Re: John Deere M alt in reply to Clooney, 12-23-2002 17:21:24
Cloney yes it has the matal cover and says delco on it. I found the 4 on the right pin and it looks like a 3 on the one next to it. I will send you my mail adress when my daughter has time to show me how. Do you think you can help me with what I gave you.
Clooney
12-23-2002 18:15:31
 Re: Re: Re: Re: Re: Re: Re: Re: John Deere M alt in reply to Al Underwood, 12-23-2002 17:42:04
Al, I have a pretty good idea what you are working with & will modify my drawing a little to reflect your set up. Try to send me your E-Mail address so I can send the diagram to you. You need to furnish an E-Mail that you can receive E-Mail at, or just have your daughter send me an E-Mail & I will return to that address..
Al Underwood
12-24-2002 07:04:15
 Re: Re: Re: Re: Re: Re: Re: Re: Re: John Deere M alt in reply to Clooney, 12-23-2002 18:15:31
Thanks clooney that digram you sent to my daughter is what I was needing to get this alternator hooked up. All my parts seem to match your drawing. I will let you know how it works when done.
Elmer
12-23-2002 12:20:59
Nat_
I went through the same thing on my 40 about 6 months ago. I bought a 40 with a hacked up alternator system on it. Mr. clooney has a great wiring diagram with good detail on what needs to be done to make those alternators charge like they are supposed to. You might want to e mail him for the detailed diagram he drew up. I am not much of a wire guy but managed to follow the diagram and it has been working great ever since. Good luck on yours/
John T
12-23-2002 12:02:05
Nat, I can help you if I know what type of alternator you have. From your description, it may well be a Delco 10 SI which is what many people use and it does indeed need the excitation voltage to operate. Does it have two little side terminals marked 1 or R and 2 or F with the big lead out the back going to the battery???? If the wires your talking about are what I think they are (a guess only) it may be the hot excitation wire thats supposed to go to 1 or R on the GM 10 SI Alternators. When I wire those set ups, I use a wire that feeds the ignition (hot only when ignition is on) and install in series with it a 5 ohm resistor and a 50 volt 3 amp or so diode so that when the ignition is turned off, the alternator doesnt back feed the coil keeping the tractor running. Post back more information and we can get you going or can post or e mail a complete wirign diagram. There are many many ways to accomplish this like switches etc etc, but I like it best with no extra switches, just turn on the key and go. Good Luck, Merry Christmas, Ol John T Nordhoff
Wayne in Tn.
12-23-2002 11:15:46
Nat. Just install a push button between the two wires. This is a simple way to do it. After starting the engine, just punch it one time and forget it.
Wayne in Tn.
12-23-2002 15:04:52
 Re: Re: John Deere M alt in reply to Wayne in Tn., 12-23-2002 11:15:46
Wow!! Well he did ask for a better way.....
Clooney
12-23-2002 11:14:13
Nat, depending on the type of alternator used, those wires are probably the excitation wires to get the alternator to charge. If you tell us the alternator brand & type I will send you a wire diagram showing how to wire it to start charging automatically. It's probably a Delco 10-SI of some sort, but if it is different than a 10-SI the wrong diagram could send you down the wrong road.
~If it's a Delco alternator, are the 2 side terminals running [--] or [ || ]?
~If you can't determine the alternator type, or just want to use what's there, just go to your local auto parts store & buy a 2 terminal oil pressure switch with a 1/8" pipe thread base [not a sender but a switch] & plumb it into the oil pressure circuit where the oil line attaches or at the oil filter & just hook the 2 wires to that. When it is running the oil pressure will close the switch & get the alternator charging & when you shut it off,the oil pressure switch will open & open the circuit for those 2 wires. Simple as that..... ..
