4020 MW turbo ?
Cecil
12-30-2003 18:59:31
I am looking at a 4020 with a M&W turbo on it. The gentleman that put it on after he overhauled it a year back died and it has set since then. Everything looks to be plumbed up right but I don't know if there is an oversized oil pan and a bigger fan on it. The fan on there now has 5 blades on it. I haven't been around enough 4020's to compare. Will this engine last if it doesn't have a different fan and oil pan on it or can it get by without them? Thanks.
Jason
12-30-2003 20:01:05
 Re: 4020 MW turbo ? in reply to Cecil, 12-30-2003 18:59:31
My neighbor has a 4020 and he put a M&W turbo on it right after he bought it new and it has over 8000 hrs on it now with no problem and he uses it pretty hard. Just keep it cool and it will last.
Brokenwrench
12-30-2003 19:47:32
The motor will last if you don't lug it,keep an eye on the temp. and keep the oil clean. The M&W fan is the same as the fan on an INT 806 with the german diesel in it. A trip to a salvage yard will probably yield one if you need it.The big oilpans are hard to come by and very expensive. Make sure the radiator is clean inside and out.Over heating is the main problem with that setup.Try to hold your oil changes to 75 hours if it doesn't have the big pan on it.
Dr.EVIL
12-31-2003 10:44:56
 Re: Re: 4020 MW turbo ? in reply to Brokenwrench, 12-30-2003 19:47:32
Actually, It's the fan off a 756 D with the German diesel. It had seven blades on it.
