John Deere H Fan problem
JRH
12-22-2002 15:44:28
I took the fan and housing off of my tractor and now when i put it back on the fan does not want to turn when we started it. I dont know what could have happended to it bc all i did was take the houseing off and sandblast it and now the fan does not want to turn like it did before i took it off. What i want to know is if the gear up in the tractor runs off of a clutch and it will start spinning when the tractor is running. Because we were not successful at pulling it off. We are still going through some carb and mag problems that have been fixed but i am concerned about the fan not spinning. Its been a while since we have even moved the tractor so i have not a clue.
Gordon
12-24-2002 07:04:49
 Re: John Deere H Fan problem in reply to JRH, 12-22-2002 15:44:28
The gears are held in place with keyways did you check to see if they where sheared.Then it could slip on shaft.
Donny-B
12-22-2002 16:49:18
JRH, As the tractor "Experts" have stated, the fan gears engagement is critical. They must be set similar to a ring and pinion on a car differential. Any over/under engagement of the gears will result in damaging the teeth. There is a section in the I&T John Deere shop manual (JD-4), page 24, that has a brief explaination on proper gear engagement. If you did destroy the gears get out your check book as Deere charges about $290 a set.
John T
12-22-2002 16:26:16
Im not quite sure what you mean by "it does not want to turn"??? Is it turnign some but makign a grinding or whining sort of noise or not turning at all?? My guess is you removed the fan and tube and not the governor, but if you didnt remove or add any gasket shims between the fan mount and governor housing, it should be the same. There's not any clutch in there, theres a set of matched gears between the governor and fan shaft which requires a proper heel/toe, mesh and backlash to operate properly. Let us know, Ol John T
Gordon
12-22-2002 16:13:10
Does it have a rubber hub on fan shaft. If it does that coud be bad. If clutch drive the friction disk could be tight on spline fan shaft.They do not have rubber hub anymore.You would have to get an asy.
Gordon
12-22-2002 17:02:39
 Re: Re: John Deere H Fan problem in reply to Gordon, 12-22-2002 16:13:10
I am talking about on the fan its self. By the radiator. There is a clutch there. The fan can be loose on shaft. It is pressed together with a spring or the fan has a rubber molding.
Clooney
12-22-2002 16:06:08
JRH, what "housing" are you referring to? Just the fan & hub, or the whole fan tube back to the governor? If the complete fan tube, did you use the same thickness shim that came out from between the fan tube & governor housing? If not there is a chance you tore the fan gears up between the fan shaft & governor drive gear when you started it. ~If it runs, the governor is spinning, it the fan shaft isn't spinning your problem is more than likely in the fan gear to governor gear area.
JRH
12-22-2002 23:20:49
 Re: Re: John Deere H Fan problem in reply to Clooney, 12-22-2002 16:06:08
Ok this is what i did. I took the fan tube i guess that is what you would call it off. I sanded it off and replaced the pulley for the generator because my father broke it in half. I replaced the pulley and put it back on. Now there is some wear on the gear inside of the tractor and the gear on the end of the shaft. But that could be from it being 62 years old!!!! I put the one thick and two thin gaskets on it. I had to make the thick one bc john deere does not make it anymore. I thightend it up and bolted it all down. We tried to pull it off and it started for a minute and died but the fan didnt want to turn but just a little bit. So i got it back in the shop and took the fand tube off and looked at it. Now i dont know how to time it if that is what it needs or i dont see how i could have messed it up when i put the new pulley on it because it only can go on there one way. Does the gasket shims matter that much i mean they are thinner than a peice of paper. I also found alot of slack in the gear up in the tractor that powers the fan. I dont know if this tells any more of my problem to help you guys out. But if you need to know more details about this just ask and i can surely get you some info to help. Thanks for what you have already told me, JRH
larry H
12-23-2002 21:51:15
 Re: Re: Re: John Deere H Fan problem in reply to JRH, 12-22-2002 23:20:49
If you have not already discovered your problem and you have the fan and shft off, hold the fan "tube" in one hand and turn the fan gear with the other--does the fan and generator pully go around? If they do they your problem is in the shimming and no where else.
Clooney
12-23-2002 05:00:43
JRH, those gaskets [shims] are very important & must be correct or the fan gears will not mesh correctly. While the gasket thickness usually won't keep the fan from spinning it could allow the gears to self destruct while running. I guess what we need to know is if the pulley spins & the fan doesn't, or if both the fan & pulley won't spin?
JRH
12-23-2002 08:50:42
 Re: Re: Re: Re: John Deere H Fan problem in reply to Clooney, 12-23-2002 05:00:43
How can the belt pulley for the generator spin if the fan doesnt. I think the problem is that i need to just put the fan back on without a shim or two. I dunno yall tell me. When i took the fan tube and fan off i can sit there and spin the fan just fine. But now the gear inside the tractor doesnt want to catch it to make it spin. JRH
Clooney
12-23-2002 09:04:36
 Re: Re: Re: Re: Re: John Deere H Fan problem in reply to JRH, 12-23-2002 08:50:42
JRH, I take it from your response that the pulley doesn't spin either? If so, I doubt just removing a gasket/shim or two will get you going. Once those gears get torn up they need to be replaced & the heel line up & backlash re-set.
~Your next step is to pull the fan tube from the governor & see what the gears look like. If the gears are bad you will have to pull the governor as both the fan & fan drive gear on the governor need to be replaced as a set. You will need the governor off to set the gear heel line up.
JRH
12-23-2002 10:49:36
 Re: Re: Re: Re: Re: Re: John Deere H Fan problem in reply to Clooney, 12-23-2002 09:04:36
I took the fan tube off and i can see the gears. They have a small amount of wear on them. Are you talking about the gear that runs the mag?? But i think i am understanding what is wrong a little bit more. Well find out.
Clooney
12-23-2002 10:58:19
 Re: Re: Re: Re: Re: Re: Re: John Deere H Fan problem in reply to JRH, 12-23-2002 10:49:36
JRH, the gear that runs the mag, [actually the governor] is probably ok or the engine wouldn't run. If the engine runs, that means the governor is turning & your problem is likely in the fan drive or driven gears.....
JRH
12-23-2002 23:20:36
 Re: Re: Re: Re: Re: Re: Re: Re: John Deere H Fan problem in reply to Clooney, 12-23-2002 10:58:19
Thanks for the help i am going to figure it out on what yall have told me. I just have one more question. I do not understand how the gasket can play such an important part in it. I have been told that if you dont put the gasket shims on it there will be a problem. Can you explain how a less than paper thick gasket shimm can make really that much differance?
Clooney
12-24-2002 04:40:03
 Re: Re: Re: Re: Re: Re: Re: Re: Re: John Deere H Fan problem in reply to JRH, 12-23-2002 23:20:36
JRH, those gears are helical & the teeth on one gear must be in the correct location on the other gear for correct engagement. Those gaskets between the fan shaft & governor control the gear engagement depth [heel position]. The gasket between the L/H governor cover & governor housing control the gear back lash. ~If the gears have been run in one place for a long time then they are moved to a different engagement position the gears wear quickly & can even self destruct.
~One thin gasket makes little difference but a couple of thin ones, or a thick gasket can make a big difference.
