35 B temp gauge
Roy
12-22-2002 11:24:25
A friend just purchased a 35 B with serial number 3847. It only has a oil gauge, there is no temp gauge. At first I thought it was removed for some reason over the years, but after looking there is no place on the upper water pipe for the temp probe to insert. Is there no water temp gauge on the early B, or if it needs one where do you monitor the water temp at.
Thanks
BMAN
12-22-2002 12:23:47
 Re: 35 B temp gauge in reply to Roy, 12-22-2002 11:24:25
The temperature gauge wasn't standard equipment until serial #12743. At that time you could buy a different upper water pipe with temp gauge fitting. Also there was a special bracket that held the gauge. I think it's better to leave the 35 B's original but that's just my opinion.
gwh
12-22-2002 20:21:22
 Re: Re: 35 B temp gauge in reply to BMAN, 12-22-2002 12:23:47
BMAN, Or one could install the accessory MotoMeter listed in the parts book(if you could find one-sure would like to find the cap parts if only to have them reproduced as the small MotoMeter is still being made). gwh
