3020 question
Shawn
12-22-2002 10:45:21
Recently purchased a 65' 3020 powershift diesel with 4200 hrs.It has a oil leak out the front cylinder exhaust port.I was wondering what the most likely cause of it would be.Any ideas?
Brokenwrench
12-22-2002 11:26:14
 Re: 3020 question in reply to Shawn, 12-22-2002 10:45:21
What you are seeing may not be an oil leak, but condensation mixed with unburned fuel and soot. The manifold bolts could be loose, or the gasket leaking, this could also be caused by a leaky valve cover gasket causing oil to run down over the manifold. Try tightening up the manifold bolts and take the tractor out and work it, getting it up to temp. and see if it doesn�t clear up.
