Head studs
jay haynes
12-21-2002 19:04:50
i am rebuilding a jd G.what is best to use for a sealer on the head studs?my book says to use white lead.i dont know what this is or where to get it.thanks.
Clooney
12-22-2002 08:45:39
 Re: head studs in reply to jay haynes, 12-21-2002 19:04:50
Jay, you can use most anything such as pipe dope or pipe sealer. I usually use LocTite 266 as that not only seals but keeps the studs from turning once it cures. If you ever want to remove the studs you will need heat though as that LocTite 266 holds extremely good.....
