JD cultivator
Phil Johnson
12-21-2002 18:45:52
Recently aquired a JD 900/920 cultivator,2 steel wheels, hydraulic lift, (cylinder missing). I would like to know approximately when this unit was made, and any other info on it.
Bob Collins
12-22-2002 13:35:39
 Re: JD cultivator in reply to Phil Johnson, 12-21-2002 18:45:52
Phil, I got one of these recently and have not had too much success finding build era, I did get an operator's manual (OM-N97683N) which says it was built in 8 and 12 foot widths, and hydraulic lift, hand lift, and power lift. For the hydraulic lift, the cylinder is not actually a part of the cultivator, you would just use the cylinder you had for whatever tractor you have. There were sub-surface standards, coil spring standards, and stiff standards available with sweeps or chisels and the wheels could be steel or rubber tires, looks like it was made for maybe 20 years in the 40s and 50s. :) Bob
