46a loader for 4020
Ray
12-21-2002 16:12:34
I bought 46a loader and am putting it on a 4020d 1968 I need some help can I get My tires on 30in rows with it on ? 18.4/34 Which set of holes do I use For the back brackets ? Does the front bracket use the weight spacer boltswith nuts or bolt directly to front Thanks for the help Remember the reason for the season
Phil
12-23-2002 07:32:41
 Re: 46a loader for 4020 in reply to Ray, 12-21-2002 16:12:34
Little off topic but what is a 46A loader going for. I have one and am considering selling it. Curious what it is worth, I have a 7' bucket, a 7' v-plow and a 3 1/2' manure bucket.
Ray
12-23-2002 17:43:42
 Re: Re: 46a loader for 4020 in reply to Phil, 12-23-2002 07:32:41
I gave 850 for it Id call it a 9 on a 1/10 scale im in indiana
thurlow
12-21-2002 18:48:00
Ray; have got 2 of these old loaders on 4020s. One of them for about 35 years. Front bracket bolts directly to tractor; will look at rear bracket and get back to you.
thurlow; RE: rear brackets
12-22-2002 08:00:08
 Re: Re: 46a loader for 4020 in reply to thurlow, 12-21-2002 18:48:00
Looked at rear brackets when I went to feed; mount them in holes which will put brackets as far toward front of tractor as possible. Side-to-side; use 2nd and 3rd FULL slots (from center of tractor) which are cast into axles; not counting partial slot which is only in top of axle. I mount fender on top of bracket, though I suppose you could put it beside bracket, depending on wheel spacing. With 18.4 tires set 76 inches center-to-center, there is about 6 inches clearance between bracket and tire. Some unsolicited advice; front bracket or front bracket bolts (or both) will eventually fail with heavy use; two straps welded to bracket and extending up to additional holes in tractor front cap will give you 4 bolts to hold it on, instead of just two. A metal 'stirrup' about 8 or 10 inchs wide and extending down 8 or 10 inches and bolted or welded on left frame just in front of left tire really helps in getting on and off tractor; just don't stick it down so far that it won't clear front axle (assuming WFE) when attaching or detaching loader. These are not as heavy (or expensive) as some of Deere's other loaders, but they're a good "fit" for your tractor. ENJOY....Happy Holidays ..... ..
