3020 Diesel with oil in antifreeze
Red Man
12-30-2003 16:55:32
I have a '71 model 3020 Diesel with engine oil in the antifreeze. It's in a Deere dealer's shop with the head off, and can't see any obvious place where the head gasket was leaking. Tractor has 5600 hrs. on it, don't know if it has ever been apart. They sent the head out to be checked, and are going to pull the oil cooler off and check it. If the head checks out, and the cooler checks out do you think I have a cracked liner?
jdemaris
12-30-2003 18:51:50
 Re: 3020 Diesel with oil in antifreeze in reply to Red Man, 12-30-2003 16:55:32
I agree with Ron. I was a Deere mechanic most of my life and never came across and engine with oil getting in coolant that was caused by leaking sleeves or head gasket. Coolant getting into oil is a whole different story and often winds up spinning a main bearing. With a 3020 or 4020, your type or problem is just about always caused by the cooler on the side of the engine leaking.
Mickey
12-30-2003 18:32:50
It is probably a cracked or a pitted liner.
steve
12-30-2003 17:06:17
you might as well pull the sleaves as the orings are the most common sorce of water in oil
Red Man
12-30-2003 17:36:25
 Re: Re: 3020 Diesel with oil in antifreeze in reply to steve, 12-30-2003 17:06:17
I don't have water in my oil, I have oil in my radiator.
Ron
12-30-2003 18:08:58
 Re: Re: Re: 3020 Diesel with oil in antifreeze in reply to Red Man, 12-30-2003 17:36:25
Sounds like the oil cooler is leaking.The oil pressure is greater then the pressure in the radiator that is why there is oil in the radiator. Good luck. Ron
