401B won't go(Jonathan help
Ron Costa
12-20-2002 19:34:19
Jonathan,you gave me some things to try on this 401B. I, put it in 2nd thu 4th gear,and revved it up,then stood on the brakes. It just sat there and labored very little. I then put it in reverse and it didn't move or stall either. Its the same in the higher range. What do you reccomend next? Thank you for your help,Ron N.J. PS, Happy Holidays to everyone!
Jonathan
12-21-2002 02:30:37
 Re: 401B won't go(Jonathan help in reply to Ron Costa, 12-20-2002 19:34:19
hello...usually that is attributable to low engagement pressure in the reverser. Did it occur right away or was it a gradually occuring problem ?? The good thing is that it is usually easy to fix. Check the clutch pedal linkage. There is a rod connected to it that can get bent and alter the pressure...also there is a pin that joins the clutch linkage to the reverser control valve that gets worn or breaks...it is located where the cross tube from the clutch linkage connects to the reverser control valve on the right side of the machine...If all looks intact, then maybe have to go through the clutch pedal linkage adjustment...let me know if you need that...
