Baker Fan questions
Chris
12-20-2002 17:50:02
I have a few questions. I would like to build a fan to load my tractors with. I think that i have enough stuff around to build one. I just need some specifics if anyone has some good pictures i would like those. I wanna know are the paddles rigid or are the loose and stand up as it spins. Also some good ways to attach them to a shaft. And finally a creative way to quickly change pulleys and what to build pulleys out of. Thanks
HaySam
12-21-2002 06:28:50
 Re: Baker Fan questions in reply to Chris, 12-20-2002 17:50:02
Chris My idea on a fan is to have enough volume of air to load your tractor,have a way to control the amount of air going in.
With air supply shut off would be easy to turn I think one speed would do all tractors under 100 hp. You want it balanced good .
HaySam Southwest Ark
Bob-Wyo
12-20-2002 20:06:48
Chris go to tractor photos on the left of screen and look at 38 D on fan. That will give a little idea about the one I built, the width of the blades is OK but think I should have made the depth only 12"
Also found the tire setup works great, using a 11L tire and rim.
What you are looking at is the remains of a threshing machine cylinder, and 2" channel iron for slats.
Bob - Wyo
Ps thats a small one in the front of the pic.
