3010D Hydraulics
Robert
12-20-2002 11:47:52
3010 D Dual Hydraulics
Loader on...slowly allows the bucket to go forward...height remains stationary, even when off and parked...Is the problem mainly in one set of the hydraulic couplers...
G-MAN
12-20-2002 12:30:45
 Re: 3010D Hydraulics in reply to Robert, 12-20-2002 11:47:52
Providing you have separate couplers for lift and tilt (rather than a separate valve running off of one coupler), the easy way to diagnose where the problem lies is to swap the couplers - plug the loader lift hose into the coupler the tilt hoses are currently in and vice versa. If the problem changes to a loader settling problem, it's likely in the tractor - if it remains the same, you probably have a tilt cylinder or cylinders bypassing oil and allowing the bucket to settle.
