Clooney starter help
peter
12-30-2003 16:30:27
Hi Clooney, I need help soldering stud going through starter case to fields. I have tried with solder gun, butane torch, and propane torch. Propane works best but I melted the stud insulaters help please Pete in Michigan
Clooney
12-30-2003 17:12:19
 Re: Clooney starter help in reply to peter, 12-30-2003 16:30:27
Pete, that stud is a big heat sink as you have discovered.
~The first thing you HAVE to do clean the wires & stud until they are both shinny [if there is any of that dark oxidation on the wires or stud it just won't solder no matter how hard you try].
~Then tin both the wires & the stud with a good rosin core solder, then hold them together & solder them.. Clean the outside of the solder with a scotch pad before using also.
~It sounds like you are getting the stud more than hot enough if you are melting the insulators..
~I use a large old style electric soldering iron [it has an end about the size of a small tire iron] . That thing dims the lights so it has a pretty big element in it..
~A direct flame is not a good idea as it burns everything around it.. Maybe you can heat a bolt or old rod with a torch & use that.
~My guess is you don't have the connection clean enough..You might also need a better rosin soldering flux..
~In real old oxidized cases where you can't get it completely clean sometimes you will need to use acid core solder [I hate the thought on electrical wires but sometimes that is all that will flow out on those old oxidized connections].. If you need to resort to the acid core solder make sure you neutralize the acid & clean the joint REAL GOOD after it's soldered..
[email protected]
