Clutch Lever Bushing on a D
cheg
12-19-2002 19:56:51
Tonight I took my clutch lever apart to fix the excess side to side movement on my 35 D. The bushing looks like a brass cap that fits over the bolt. Does anybody know if John Deere still makes these bushings? If not, does anybody have any ideas to repair this?
Clooney
12-20-2002 04:51:41
 Re: Clutch Lever Bushing on a D in reply to cheg, 12-19-2002 19:56:51
Cheg, I don't know what to tell you. I usually make my own bushing on those old D's so I get a tight fit without replacing the pivot pin. ~There is a little discrepancy in the parts book, but I believe the A-1197R bushing should fit. It doesn't list a bushing for your '35 but the lever & pivot is shown the same as the later D's so I have to think the later A-1197R bushing should fit. ~You could probably find a generic brass bushing from your local TSC or hardware store & press that in, then drill the center out to fit your pivot pin. [most generic bushings will probably have a thicker wall than the correct bushing you need, so will have to be drilled out]....
Jimbob
12-22-2002 16:31:00
 Re: Re: Clutch Lever Bushing on a D in reply to Clooney, 12-20-2002 04:51:41
Just a quick note to say Yes, the bushing was still available as late as last fall. I purchased one for my '31 and I also believe it to be the correct one for your application..... ..
