JD B transmission
Brandon
12-19-2002 17:14:39
I have a 49 B that gets stuck between gears once in a while. Anyone know what causes this and how I can fix it?? How hard is it to rebuild the transmission? Any ideas and information are greatly appreciated. Thanks, Brandon
Gordon
12-19-2002 21:13:09
 Re: JD B transmission in reply to Brandon, 12-19-2002 17:14:39
Check how loose is the shift lever. There are four bolts under the quadrand if they are loose the gasket is gone also. You can ajust the shifters on the left side of tractor. You have to remove the flywheel and the side cover. There are bolts going through a ajusting screw. By turning the screw in or out it will change the shift lever in the quadrand. Try to get it so it dorps into detent about the same time you can get in or out of shift quardrand or corner.
