70 stuck in gear
Alan
12-19-2002 17:05:50
Was trying to level up where my shop is going went from Reverse to 1st low range and now it is stuck inbetween gears wont come out of low or go into reverse and its wont go up to 3rd or 5th need to get my dirt moved rain is coming next week.
Thanks Alan
Alan
12-19-2002 18:33:19
 Re: 70 stuck in gear in reply to Alan, 12-19-2002 17:05:50
Well I guess its slip the top off time I tried what you said Clooney and it wants to go but just wont quite get there Thanks Sir and Thanks Pat get to work on it tommorow before I get to play with it but thats ok just wish its new home was ready concrete will sure beat looking for nuts and bolts in the dirt lol Thanks again guys.
Alan
Clooney
12-19-2002 17:21:07
Alan, try moving the Hi-Lo shift lever back forth, maybe it will kick it back into reverse. If that doesn't help you will probably have to pull the trans shifter cover & line the shift rails back up.
~Be slow & deliberate on the shifting & put the Hi-Lo shifter in lo before shifting to rev & you probably won't have any more problems. .....
Pat
12-19-2002 17:19:46
Hi Alan! It is possiable that the shift lever slipped by the shifter rail. The way I check these is to unbolt the quadrant from the tractor and set all the shifter rails to the netural position. then bolt your quadrant back in place while the lever is in netural and you should be all set. I have a 70, 720d, and 730d that people doing me "favors" have slipped that shift lever past the forks. You might have a broken shift lever, but I don't think so. Your transmission is probally worn causing this. Hope I helped.
