Instructions for replacing load seals on 3010 ( other models of course)
Scott Trautman
12-18-2002 08:04:49
Hi--
Had some swell folks here help me diagnose the problem, and give me some hints on how to replace the load seals on my 3010.
I've put up a page that describes the whole process. Got additional tips on this job? I'd be happy to update the page.
Link
twopop
12-18-2002 16:51:20
 Re: Instructions for replacing load seals on 3010 ( other models of course) in reply to Scott Trautman, 12-18-2002 08:04:49
looks good,thanks.would like to see you add.
set draft control lever {below ,and to right side of seat,near platform}to lowest position.this will release pressure on the shaft and make it easier to install new shaft.
install shim washers between rear housing and wishbone so wishbone does not move sideways
check bushings in wishbone,replace if worn,especially if installing new load control shaft
