Brass Questions
Mike N
12-17-2002 10:43:21
What does a it mean when a tractor has a brass serial number tag? Does it mean early production or something else?
Also, when were brass carbs used on unstyled A's.
Thanks!
Will P
12-17-2002 20:17:07
 Re: Brass Questions in reply to Mike N, 12-17-2002 10:43:21
I think it is just people trying to make there tractors sound more important. Don't get me wrong. I'm not cutting on anyone. But I don't go around saying I have a steel tag A and B.
Will P
Craig
12-17-2002 20:34:21
 Re: Re: Brass Questions in reply to Will P, 12-17-2002 20:17:07
I read an article once in one of the JD magazines that a brass tag meant nothing. You always see ads saying brass tag B or A as though it is suppose to be worth more. It's NOT!
Will P
12-17-2002 21:55:08
 Re: Re: Re: Brass Questions in reply to Craig, 12-17-2002 20:34:21
You got it. A tag is a tag is a tag.
Will P
Roy
12-17-2002 15:57:52
I don't think a brass tag means anything at all. I have a 1955 Model 70 with a brass tag. Nothing special about it.
Randy
12-17-2002 14:24:50
I know the first unstyled As had brass carbs on them. I have a 1934 which is the first production year John Deere made the A. I believe the number on the carb is DLTX-8. I'm not sure when they switched over though.
As for the serial number on the tractor, all of the 34As and I know at least some of the '35s were brass tags but once again, don't know when this changed to aluminum tags.
matt wagner
12-17-2002 17:17:08
 Re: Re: Brass Questions in reply to Randy, 12-17-2002 14:24:50
the dltx8 carb was used on the 34 and 35 production years i have a 34openfan ser.411433 and a 35openfan serial 414200
as for the brass tag the early tractors had brass tags up to the year of 36 i have a 36br brass tag and a 35B brasstag 36AO brasstag ser. 251433 hope this helps MATT
charlie
12-17-2002 15:47:09
35--38 B's were unstyled, but I'm pretty sure that only the 1935's rec'd a brass tag serial #
