How much oil in trans right side cover? 51 B
Moto Head
12-17-2002 06:32:35
Still waiting on my manuals, so here is another question. 1951 B, Right behind the belt pulley in the right side of the engine is the engine oil fill, and next to that is another pipe plug filler. I found the small drain plug under it on the trans side cover. Question is how much oil goes in here?, some one told me a quart, but he didn't sound too sure. Also should it be 90w like in the trany?
Thanks, MH
gwh
12-17-2002 10:08:00
 Re: How much oil in trans right side cover? 51 B in reply to Moto Head, 12-17-2002 06:32:35
Moto Head, The reduction cover for both the very late styled A and the late styled B call for 1 pint of fresh engine oil. I also run a wire(piece of coat hanger wire)in the hole in case it doesn't drain well, seems that pocket traps a lot of crap(oil, water etc.)The letter series tractors used engine oil while the number series tractors used transmission oil. gwh
52BMAN
12-17-2002 08:37:17
The correct amount of oil is one pint not a quart. An "A" JD holds a quart. Your manuals will show this when you get them.
Bob Weber
12-17-2002 06:53:24
The first reduction gear is oiled by engine oil. If you drain the first reduction cover (I always do when I change oil) refill it with a quart of engine oil, and also fill the engine crancase to the proper level. Don't worry about overfilling the first reduction cover, as once it reaches a certain level it will flow back into the crankcase.
Moto Head
12-17-2002 06:38:02
The proper name for the side cover I'm talking about is: First Reduction Gear Side Cover.
