What percentage weight on back wheels
John L.
12-16-2002 18:47:34
Does anyone know how the percentage of weight the 730D had on the back wheels as compared to Super MTA, Oliver 880, or maybe UB Moline?
G Taylor
12-17-2002 08:53:51
 Re: What percentage weight on back wheels in reply to John L., 12-16-2002 18:47:34
Two wheel drive bias ply tired tractors are supposed to weight between 115 to 145 lbs per pto HP. Static weight is to be 65/45 rear front for drawbar loads. Travel speed at 100% engine rpm and at 80% max HP is to be between 3 to 5 mph.
leon
12-17-2002 04:37:29
Nebraska Tractor Test Reports will give you that information. By the way, does anyone know where they just might be available on-line?
LFN
12-17-2002 06:23:07
 Re: Re: What percentage weight on back wheels in reply to leon, 12-17-2002 04:37:29
You might look at Link
leon
12-17-2002 18:05:37
 Re: Re: Re: What percentage weight on back wheels in reply to LFN, 12-17-2002 06:23:07
When I try to go there I get the following message:
"Sorry, File Not Found
The requested file does not exist. This link is either inaccurate or outdated."
Perhaps we're both outdated.
Ralph Ia
12-16-2002 19:33:05
J D two cylinders were 70/30. Others were 50/50
John L.
12-17-2002 17:57:31
 Re: Re: What percentage weight on back wheels in reply to Ralph Ia, 12-16-2002 19:33:05
Thanks for the information.
We farmed a long time with Molines. I was always amazed at how different the rear tire tracks looked on a John Deere two cylinder and the Moline. The John Deere track was always full width where the Moline was not so full. It had to be the extra weight on the rear of the John Deere that made the difference.
G Taylor
12-17-2002 19:05:28
 Re: Re: Re: What percentage weight on back wheels in reply to John L., 12-17-2002 17:57:31
When watching the two cylinders on the balance beam, they usually balance fore/aft with the crankshaft being the centerline.
