Fuel filter replacement----4010D
Scott Williams
12-16-2002 05:57:19
I have a 4010D with the cartridge type fuel filters. I would love to use something different, due to the aggravation of this setup. Whoever had the tractor before me was rather fond of silicone to stop the filter canisters from leaking. Will the dual screw-on setup from another tractor fit in the place of the original setup?
Gary in TX
12-16-2002 14:03:17
 Re: Fuel filter replacement----4010D in reply to Scott Williams, 12-16-2002 05:57:19
I will ditto Dans advice on the snap on glass filter. My 4020 has that and my 3020 will have it sometime this next year. Its just a lot nicer adn you can see the fuel and know you have it bled. Its very easy to replace and the filter is about 9.00. I got one just a short time ago.
Scott Williams
12-16-2002 14:46:18
 Re: Re: Fuel filter replacement----4010D in reply to Gary in TX, 12-16-2002 14:03:17
Thanks. I'm gonna try to make the original setup work first, just to keep it original, but that'll be my next step.
Gary in TX
12-16-2002 15:46:49
 Re: Re: Re: Fuel filter replacement----4010D in reply to Scott Williams, 12-16-2002 14:46:18
Nothing at all wrong with the original as far as I can tell. I just use mine in a custom baling business and need them as easy to service as possible. You might try going to the original 4020 sytle filters however. They are a spin on type.
Dan S
12-16-2002 07:03:51
the 2 screw on filter assembly will work fine, but they also like to leak. I would go with the 1 glass filter that snaps in place that was used on the newer 3020, 4020, and most models after that. The only time these will ever leak is if the strap that snapsthe filter on is worn out, but that is not too expensive to replace.
